Sonarr version (exact version): 2.0.0.4427 Mono version (if Sonarr is not running on Windows): Windows OS: Windows 10 ((Debug logs)): http://pastebin.com/raw/LUpJ9z78 Description of issue:
When Sonarr tries to rename Con Man episodes, instead of naming them like normal it names them something weird like “HSOG3~K.MKV” (that’s not the exact name, but it’s something like that). I see that the logs say it can’t access them, but it does rename them. Also, I can rename them manually. This is only happening with Con Man episodes (s02e01 and s02e02), and not with any other show.
CON is a reserved word in Windows from the DOS days, so renaming files with it as a separate word won’t work properly (though I was under the impression renaming would fail, not create a DOS compatible name).
