Tried finding an existing thread for this, but couldn’t find one, so hopefully this isn’t too weird a problem!
My Sonarr seems to be finding and downloading shows fine, but when the download completes, no matter what show is downloaded, it thinks it’s an episode of Top Gear and renames, copies and sorts it into the Top Gear folder on my HDD.
I can’t work out why this is happening, any help would be great
All downloads go into a root folder called “Downloads”.
So for example, Sonarr detects a Game of Thrones episode is available, it downloads a GoT file in Sabnzbd, Sonarr then detects the downloaded file but renames it as Top Gear and sorts it into a Top Gear folder, instead of the Game of Thrones folder.
But strangely enough if I put a file into the download folder manually (say copied from my desktop), Sonarr renames and sorts it correctly!
I’m not using any scripts either.
My folder structure worked perfectly fine with Sick Beard.
Thanks Markus - I had a quick look through logs - couldn’t see anything standing out. So I re-checked Sabnzdb and it was for some reason, downloading into a /downloads/top gear/ folder… So thats what it was!
I hope that’s all it is! Can’t wait to use Sonarr.
