Hello, I am pulling my hair out on this renaming issue I had everything setup previously with a MHDFFS drive pool but kept gettting a seg fault error so I switched to a AUF pool. Ever since then sonarr will not move or rename files. I have it setup so Sabnzbd drops all the completed files into a completed/Tv and give 777 permissions to the files. The download directory is owned by Sabnzbd and the folder where sonar is suppose to move the show is owned by sonar both users are in the same group and have read/write access to both folders. I have included the error log below aswell as a printout of ls -l of the tv download directory. Any help would be greatly appreciated.
Sonarr Ver. 2.0.0.3357
Openmediavault 2.0
> Couldn't import episode /media/4a95f9af-8889-4f99-9fc0-89d4884241f8/Media/Downloads/NZBS/Complete/Tv/Archer.2009.S03E07.720p.BluRay.X264-REWARD/Archer.2009.S03E07.720p.BluRay.X264-REWARD.mkv: Lock violation on path
> System.IO.IOException: Lock violation on path
> at System.IO.File.Move (System.String sourceFileName, System.String destFileName) [0x00000] in <filename unknown>:0
> at NzbDrone.Common.Disk.DiskProviderBase.MoveFile (System.String source, System.String destination, Boolean overwrite) [0x000d0] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskProviderBase.cs:210
> at NzbDrone.Common.Disk.DiskTransferService.TransferFile (System.String sourcePath, System.String targetPath, TransferMode mode, Boolean overwrite, Boolean verified) [0x003a6] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskTransferService.cs:202
drwxrwsrwx 2 sabnzbd users 4096 Jul 30 01:03 Archer.2009.S01E03.720p.BluRay.X264-REWARD
drwxrwxrwx 2 sabnzbd users 4096 Jul 31 18:00 Archer.2009.S01E04.720p.BluRay.X264-REWARD
drwxrwxrwx 2 sabnzbd users 4096 Jul 30 07:59 Archer.2009.S01E05.720p.BluRay.X264-REWARD
drwxrwxrwx 2 sabnzbd users 4096 Jul 31 18:17 Archer.2009.S01E06.720p.BluRay.X264-REWARD
drwxrwxrwx 2 sabnzbd users 4096 Jul 31 18:26 Archer.2009.S01E07.720p.BluRay.X264-REWARD
drwxrwxrwx 2 sabnzbd users 4096 Jul 30 11:00 Archer.2009.S01E08.720p.BluRay.X264-REWARD
drwxrwxrwx 2 sabnzbd users 4096 Jul 31 18:35 Archer.2009.S01E08.720p.BluRay.X264-REWARD.1
drwxrwxrwx 2 sabnzbd users 4096 Jul 31 18:44 Archer.2009.S01E09.720p.BluRay.X264-REWARD
