Hello,
I have tried to set the Rename episodes switch to on with Advanced Settings set to both “show” and “hide”. Each time I switch “Rename Episodes” to “Yes” I then click save. Invariably the next time I’m in settings and look at the “Media Management” tab, Rename Episodes has been reset to “No”.
I can’t figure out why this is happening and would very much like to fix it. Any ideas?
Version 2.0.0.3212
Mac Mini running 10.10.3
Thanks
Does it say it was saved successfully in the bottom right? Sounds like validation is failing and causing the setting to be reset.
Interesting… I never noticed before. When I tried it just now, it did. I clicked around a bunch different settings tabs, different sections of the app. Currently is persisting.
I have been rebooting a bit lately. Maybe that’s it. It’s late and I’ll try that tomorrow to see if I can break it.
Thanks for the tip!
well the problem has not recurred yet so maybe I was mistaken, or doing something else weird.
