Hello,
is it possible to rename episode per title in italian?
When i download an episode the title is in italian, but when sonarr renames it bacems in English.
Is it possible to set rename in Italian?
Tnx
This is really more to do with TheTVDB than Sonarr but it’s a good question
It’s not currently possible, but this is something that will be addressed when we move to using TVDB’s new API:
I just want to let you know that with filebot i can rename episode with italian titles with:
filebot -rename *.mkv --lang it --format “{n}.{s00e00}.{t}” -non-strict
Is there a way to rename using a script after download instead of sonarr rename?
You can use a Custom Script
to do it.
Tnx,
i made some search on forum and i saw pictures of custom script, but i cannot find menu in webif.
Can you tell me were to find it?
Settings -> Connect -> Add New -> Custom Script
