Couldn't import episode /downloads/completed/series-redacted/episode-redacted.mkv: Could not find file ""
System.IO.FileNotFoundException: Could not find file ""
at System.IO.File.Move (System.String sourceFileName, System.String destFileName) [0x00116] in <71d8ad678db34313b7f718a414dfcb25>:0
at NzbDrone.Common.Disk.DiskProviderBase.MoveFileInternal (System.String source, System.String destination) [0x00000] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Disk\DiskProviderBase.cs:232
at NzbDrone.Mono.Disk.DiskProvider.MoveFileInternal (System.String source, System.String destination) [0x00076] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Mono\Disk\DiskProvider.cs:170
at NzbDrone.Common.Disk.DiskProviderBase.MoveFile (System.String source, System.String destination, System.Boolean overwrite) [0x000e3] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Disk\DiskProviderBase.cs:227
at NzbDrone.Common.Disk.DiskTransferService.TryCopyFileTransactional (System.String sourcePath, System.String targetPath, System.Int64 originalSize) [0x00108] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Disk\DiskTransferService.cs:462
at NzbDrone.Common.Disk.DiskTransferService.TransferFile (System.String sourcePath, System.String targetPath, NzbDrone.Common.Disk.TransferMode mode, System.Boolean overwrite, NzbDrone.Common.Disk.DiskTransferVerificationMode verificationMode) [0x0034a] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Disk\DiskTransferService.cs:289
at NzbDrone.Common.Disk.DiskTransferService.TransferFile (System.String sourcePath, System.String targetPath, NzbDrone.Common.Disk.TransferMode mode, System.Boolean overwrite, System.Boolean verified) [0x0000e] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Disk\DiskTransferService.cs:196
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.TransferFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Tv.Series series, System.Collections.Generic.List`1[T] episodes, System.String destinationFilePath, NzbDrone.Common.Disk.TransferMode mode) [0x0012c] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:119
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.CopyEpisodeFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Parser.Model.LocalEpisode localEpisode) [0x0006b] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:94
at NzbDrone.Core.MediaFiles.UpgradeMediaFileService.UpgradeEpisodeFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Parser.Model.LocalEpisode localEpisode, System.Boolean copyOnly) [0x00167] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\MediaFiles\UpgradeMediaFileService.cs:72
at NzbDrone.Core.MediaFiles.EpisodeImport.ImportApprovedEpisodes.Import (System.Collections.Generic.List`1[T] decisions, System.Boolean newDownload, NzbDrone.Core.Download.DownloadClientItem downloadClientItem, NzbDrone.Core.MediaFiles.EpisodeImport.ImportMode importMode) [0x00272] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\MediaFiles\EpisodeImport\ImportApprovedEpisodes.cs:107
I set up a remote path mapping to correlate a remote container with Sonnar’s. An ls -l of both the local and remote episode’s directory displays the file, as well as its 777 chmod. Debug logs show that Sonarr cannot locate "", a blank filename, apparently. The hostnames of the download client and remote mapping match exactly. Mapping remote /data to local /downloads. I can confirm that the local path Sonarr is searching is the correct path. Tested moving the episode as the sonarr user with no issues.
Can you provide trace level log file entries? That’ll show the source and destinations paths. The “Debug logs” text in your post contains a link with instructions.
Just one more thing…I feel like this has something to do with the .partial~ file that Sonarr creates when it’s copying to my goofys-mounted S3 bucket (with an internal S3 endpoint).
After searching, I read that Sonarr will cancel the copy if the filesizes don’t match, but they do. Both are 482732988 bytes. From what I saw, it didn’t take Sonarr long to give up and delete the .partial~ file after fully completing the transfer.
I don’t think I should need the partial upload feature. Any way to disable that and test without?
Which means it completed the transfer, checked the filesize which was the same, and then instructed mono to rename the file from .mkv.partial~ to .mkv. Which caused
The copy action of 483 MB took 79 seconds, about 6.1 MB/s. Pretty slow imo, but matches what one would expect with s3.
Another thing that surprises me is that the transfer deletes both an old backup and old partial. I would’ve expected the old partial, but not the old backup.
Anyway, the blank string “” isn’t actually a blank string. That’s just mono not knowing how to log errors. Under the hood it’s just an ambiguous “File not Found” error.
It’s probably possible to get more mono internal traces with mono trace/debug options, but that’s not worth the effort. It could be more useful to trace what’s happening in that goofys filesystem driver. A quick google indicates that there are fstab flags to debug fuse and/or s3.
I appreciate your looking into it. Truthfully, I’ve never been able to use s3fs or goofys for anything more than simple PUTs and GETs. The solution here is to use ObjectiveFS, which is the only S3-backed mount I’ve ever found with full POSIX support. It works great, and it’s fast, but far from being open source. I ended up buying a license, and Sonarr’s working great now.
A lot of ppl actually use unionfs (or similar) and a sync tool to store new files locally in a cache and upload separately, one layer as write cache and the bottom layer as readonly of the cloud drive.
