I don’t think this is an issue that requires software revision info or debug logs to fix so not posting it unless requested. I think this is just me being stupid…
I have sonarr running on macos and I want to set up a download client to run directly on my NAS (SABnzb and Synology)
Sab gets added to my download client list with no issues, test comes back positive.
When I try to add an item either manually or automatically it shows up in my queue as, “pending, download client not available” Adding a remote path mapping does nothing.
I use the correct ip/client, with the correct port.
I paste in the completed SAB folder using the same format as in the SAB client for the remote path section:
/volume1/NAS/SAB/Complete/
And then I navigate to the same path for the local path in sonarr:
/Volumes/NAS/SAB/Complete/
And nothing happens, I refreshed the series, deleted it to have sonarr re-add it to see if it was just a new connection issue. I have restarted both clients. Nothing works. Sonarr doesn’t like my SAB client
