When adding a new series, sometimes I am getting the error “Error occurred while executing task RefreshSeries: The request was aborted: The connection was closed unexpectedly.” What can I do to prevent this? Log file attached.
We need debug logs (which will show you the URL used to connect)
We also need: Mono version (if Sonarr is not running on Windows): OS:
The debug logs will show the URL, if you paste that URL into your browser it should load, knowing whether or not that is working for you when it fails may help narrow it down.
Does Sonarr consistently fail with that same series?
Which browser did you test with?
Did you test from the system running Sonarr?
Is there any Anti-virus/firewalls installed on that system?
Was not an error message, just a lot of text about TV info/sites.
Hmm, maybe it was just flaky. It is working now after no changes. It was always with the one show. Others did work. I run Chrome 51.0.2704.103 m (64-bit) and yesI was running from the system Sonarr is on. I have Avast Premier and Microsoft Security Essentials running. I just thought it was weird that some shows were working and some not.
