Sonarr version (exact version) : 2.0.0.5301
Mono version (if Sonarr is not running on Windows) : 5.18.0.240
OS : Linux Mint
Debug logs :
Description of issue :
For the past several weeks I’ve had a problem with sonarr not grabbing new episodes for the Daily Show that are in the indexer (Dognzb) and hours old. This show is properly set to series type “Daily”.
This is happening every day now so I’m just doing it manually. This show has been working fine for years. I tried completely deleting the Series and re-added it, but the problem persists…
For example, the following releases were available in my indexer for 6 hours, but nothing was was found, or grabbed despite one (720p) being a valid import candidate:
The Daily Show 2019 02 14 Chris Wilson EXTENDED 720p WEB x264-CAFFEiNE
The Daily Show 2019 02 14 Chris Wilson EXTENDED 1080p WEB x264-CAFFEiNE
Sonarr dispays the episode as:
The Daily Show - 02/14/2019 - Chris Wilson
Its in the Wanted List.
No log errors for sync, just 0 grabbed:
RssSyncService RSS Sync Completed. Reports found: 100, Reports grabbed: 0
DownloadDecisionMaker Processing 100 releases
When I do a manual search, same thing, it also comes up with nothing found, and the log reports:
DownloadDecisionMaker No results found
NzbSearchService Searching 1 indexers for [The Daily Show : 2019-02-14]
Automatic search button, same thing, and nothing is grabbed.
But when I manually download the release from the indexer, and go to manually import it in sonarr, it shows up fine, correct name, date, etc, no errors, and imports with no problem.
