==> sonarr.txt <==
[v2.0.0.4645] System.Net.WebException: Error: ConnectFailure (Connection refused) ---> System.Net.Sockets.SocketException: Connection refused
at System.Net.Sockets.Socket.Connect (System.Net.EndPoint remoteEP) <0x71ab9918 + 0x001a8> in <filename unknown>:0
at System.Net.WebConnection.Connect (System.Net.HttpWebRequest request) <0x71ab5318 + 0x00423> in <filename unknown>:0
at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) <0x71aae600 + 0x001a4> in <filename unknown>:0
at System.Net.HttpWebRequest.GetResponse () <0x71aab550 + 0x0006f> in <filename unknown>:0
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x000fb] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:63
17-3-8 09:51:31.1|Warn|NzbDroneErrorPipeline|Invalid request Validation failed:
-- Unable to connect to indexer, check the log for more details
The connection was refused, something on their end (either an issue or blocking for some other reason).
