Rating is a percentage not out of ten
Hi,
I’ve recently cleared out my TV Show metadata and allowed sonarr to pull it all in fresh. Everything went well except the rating appears to be a percentage rather than out of ten. I’ve seen this discussed elsewhere with a fix being mentioned - has this been released?
I’m using sonarr 2.0.0.2594 on synology
thanks
Its a result of the switch to TheTVDB from Trakt. We’ll get that fixed up.
This is fixed in develop now.
Is it possible to switch over to the develop branch on Synology?
Yes, if you’re running a kind-of-recent version of sonarr on your Synology.
If updating works for you within sonarr itself (e.g. it updates automatically or when you click install it’s applying the update correctly), you should be good to go.
Fantastic. Thanks for the info.
