OS: Windows 10 64-bit Build 1803
Here’s the best example:
Godfather of Harlem, S03E06 - Sonarr grabbed this: https://rarbg.to/torrent/c2nw4y8 which is labelled with [rartv] but the actual torrent is labelled with [rarbg] when it’s imported in to Deluge (v2.1.1).
So I get this:
2023-02-26 01:17:29.7|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: V:\Downloads\Godfather.of.Harlem.S03E06.Spooks.1080p.AMZN.WEBRip.DDP5.1.x264-NTb[rartv]. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
Because the actual path is V:\Downloads\Godfather.of.Harlem.S03E06.Spooks.1080p.AMZN.WEBRip.DDP5.1.x264-NTb[rarbg]
Again, pretty sure this is a fault of rarbg mis-naming the torrents, Sonarr is doing what it should. Not sure if there’s any automatic work-around that Sonarr or a script can do to rename these folders to they match up… or just don’t use rarbg, which is becoming more trouble than it’s worth.
