Sonarr Version 3.0.6.1342, Windows 10
Sonarr can NOT find a single episode!
Please help…
Thank you
You’ve provided zero details and zero logs, so the help you can expect in return is about the same.
Most likely it is the indexers you are using, or how you have them setup in Sonarr.
I just did searches for random season 1 episodes and got multiple results for all.
If you have manually searched directly on the indexers you are using and are not getting results there either, then you’ve identified the issue. You need better/different indexers.
If you are getting results on your indexers, but Sonarr is not returning anything, then you need to correct your indexer settings in Sonarr.
If it doesn’t seem to be either of the above, then you need to go back and follow the template to provide logs that might help identify what the issue is.
there’s also an entire troubleshooting article on the wiki as well
https://wiki.servarr.com/sonarr/troubleshooting#searches-indexers-and-trackers
