Queue : manual cleaning torrents to improve
Hi,
I’m using the develop version 2.0.0.2964 with torrent files being downloaded with utorrent.
I asked sonarr to grab all my missing episodes and it found many torrents that were then started in utorrent : sounds perfect.
But many of them are out of seeders or don’t reach the end : to clean my queue, the only way now is to delete the torrents manually, but those torrents have to be added to the blacklist too.
So i remove them via the activity “queue” screen with the red cross and the option “add to blacklist”.
After a few hours, i delete the torrents that were inactive since more than 1h.
But this is a very long work, fastidious and annoying.
There’s no possibility to remove more than 1 at a time and another problem is the auto-refresh : if i have 10 pages of files in the queue and i want to find the one to remove, it becomes very hard to find it because i don’t have time to read all the pages, auto-refresh is back to page 1 regularly. And i can’t reorder the queue by show name or episode number to make the search easier.
Furthermore, i have to be very fast to use the remove red cross when i find the title to remove : the refresh often occurs after i clicked on the red cross, but before i had time to activate “add to blacklist” and then i can start over again !
My 2 questions :
  • is there a way to deactivate the auto-refresh ?
  • do you plan to allow removes (+ add to blacklist) for more than 1 torrent at same time ?
Thanks
Thx
I started to look into this issue, but unfortunately its quite a bit more complex than I first thought.
We’ll definitely take a look at it, just need to figure out the best way to do it, we’ll update this Trello card when its being worked on: https://trello.com/c/Fyt71HES/967-signalr-syncing-queue-causes-return-to-page-1
