Hi, Is there anyway of setting quality profile without a cutoff? Basically what I want to happen is have a profile that has HD720p, Bluray 720p and WEBDL-720p, and as long as one of those is found its downloaded and considered completed, no other quality is needed?
The default HD 720p profile does just that. Cutoff is met or exceeded (the tooltip in the UI states this). If you need more information, check out the wiki.
OK, I think I got it worked out, thanks
