Quality Sizing ignored
For some reason even tho I have set my quality and sizing and it still ignores that some times and sends 1.6gb TV show episodes to my SABnzbd and its quite frustrating cause I don’t want 1.6gb episodes - Takes up far too much space but I always have my series set to ‘Any’ because sometimes setting a quality it misses some episodes - so i figured that if i set all the sizing then i doesn’t matter what quality it is as long as it fits into my sizing I’m happy to pick up the slightly better quality episode if it is under 1-1.1gb
Not sure what I’m missing - but thanks for any advice in advance :smile:
The size limits depend on a couple things:
  • number of episodes
  • run time of series
So the actual limit is: size limit * number of episodes * run time
The UI shows the two most run times, 30 and 60 minutes, if its longer than bigger files will be grabbed.
If you’re still having issues, please pastebin some debug logs.
