Quality size not respected?
Hi,
I am totally new to sonarr so please excuse a potentially dumb question. I created a profile for sd in German including SD and DVD. All quality file size settings are still default. I created a new series and had it look for an episode which was found. But it started a download of a 9 gb DVD episode. The max for a 45 min episode should be way less. What an I doing wrong?
Regards JP
Max size is calculated as MB per minute * number of episodes * series runtime. So it either detected multiple episodes or the runtime for the series is wrong and needs to be fixed on TheTVDB. The default max size for a 60 minute show is 6GB (the defaults are not restrictive at all).
If you enable debug logging it should log the size for each release that is found (and what the max allowed is).
There are quite a few topics on this subject already, it’d be worthwhile to take a look at those as well for more troubleshooting steps.
