Sonarr version (exact version): 3.0.0.348
OS: Windows 10
Description of issue: I have a bizarre behavior. All my qualities are over 0 bytes of allowed size, but when going on selecting a torrent for a download Sonarr told me that he can’t because the maximum behavior allowed is 0 bytes (On the screenshot it’s a WEBDL-720p). Is there something wrong here? Or for some reasons Sonarr can’t get the total time of the episode?
theres no runtime set in TVDB for that show which might be why v3 thinks episodes are zero minutes long?
https://www.thetvdb.com/series/339243
v2 isnt excluding any eps for 0 minute time reasons so maybe v3 is sticking to the runtime value in TVDB and no longer defaults to (for example) 30mins when there is no runtime?
v2 would have the exact same behaviour. The runtime is used to calculate the maximum size and since anything multiplied by 0 is 0 the max would be 0.
