I am having some problems getting things to download, I keep receiving the message…
“Sorry, couldn’t find [EPISODE-NAME], that matches your preferences.”
If I do a manual check of NZB.SU then there are both SD and HD versions available.
I assume this is something to do with the Quality profiles that I have set up, they are as follows…
Intention: Download the FIRST AVAILABLE release irrespective of quality and then NEVER UPGRADE to a better quality.
Cutoff: SDTV
Selected: All qualities
Result: “Sorry, couldn’t find [EPISODE-NAME], that matches your preferences.”
Intention: Download the FIRST AVAILABLE release irrespective of quality and then UPGRADE to the best release possible.
Cutoff: BluRay 1080p
Intention: Only download an SD release
Cutoff: DVD
Selected: SDTV
WebDL480p
DVD
Anyone who can offer any advise as to how Quality actually works and where I have gone wrong?
Thanks
Harroguk
