Using Sonarr 2.0. Is there a way to configure Sonarr to perform the following steps?
- Download 1080p if 4k is not available
- Continue searching for a 4k release
- Download the 4k release when it finds it
- Delete the 1080p version when the 4k completes
Settings > Profiles
Set them how you want them and when you add the show, pick that profile.
Make sure the 2160’s are picked and the 1080’s and make sure allow upgrade is checked.
And set whichever 4k quality you want to end up with as the cutoff.
I’ll give that a try, thanks!
