Quality detection based on audio tracks
Sorry if I couldn’t find the correct existing discussion for this suggestion but a suggestion for quality scanning profiles based on audio track/
Maybe an alternative quality definition tab with audio scales from low bitrate to high, or codecs, mp3 to DTS etc.
Using the bit rate for either audio or video is not consistent enough. This card will use the resolution to make a better decision, but would still be limited to SDTV/HDTV 720p/HDTV 1080p as those are the lowest qualities in each resolution.
The main reason I suggested this is that DTS tracks combined with video resolution seem a fool proof way of detecting Bluray rips. I can see that other combinations of codecs/bitrates would be more difficult to identify.
