Quality Definitions values not being respected
Sonarr version (exact version): 2.0.0.4127-develop
Mono version (if Sonarr is not running on Windows): N/A
OS: Windows 10 Pro
((Debug logs)) (posted to hastebin or similar): ***Nothing in the log about this issue.
Description of issue: Sonarr is not using the values I’ve set under ‘Quality Definitions’. I don’t know where it is pulling the values it is showing me when I’m doing a manual search. I’ve included a screenshot to better highlight the issue.
Hover over the i icon at the top of the list, right beside Size Limit and you will get the reason:
Limits are automatically adjusted for the series runtime and number of episodes in the file.
If you go to the series details page (or TheTVDB) you can get the runtime, which is 25 minutes.
Gotcha, is there any way I can fix this so that I don’t need to do a manual download?
Your limits are too low for a higher quality WEBDL 1080p, 840MB is incredibly small for 60 1080p in any quality except for the most bitstarved Webrips, that looks like a reasonable limit for 30 minute series, but then you’d need to adjust it a bit higher to compensate for this 25 minute series.
