Sonarr version (exact version): 3.0.0.334
Mono version (if Sonarr is not running on Windows): 5.16.0.220
OS: unraid
Description of issue: Do qualities always outweigh preferred tags?
For example:
I have bluray-1080p set above web-1080p in my qualities. I have a release in web-1080p with my preferred word, but sonarr is grabbing a bluray-1080p release which does not contain any preferred words. Is this the intended behavior, and if so, is there any value I can set my preferred word to that will prioritize preferred word releases over quality?
Yes.
No, but you could group those qualities together so they are effectively the same quality.
I didn’t realize you could do this. This solution works perfectly. Thanks!
