Sonarr version 2.0.0.4389
Mono version: 2.11.2
QMono version: 4.2.1.0
Firmware: 4.2.3 on a TS-251
((Debug logs)):
17-2-5 21:15:50.2|Info|NancyBootstrapper|Starting NzbDrone API
17-2-5 21:25:35.6|Info|Bootstrap|Starting Sonarr - /share/CACHEDEV2_DATA/.qpkg/QSonarr/NzbDrone/NzbDrone.exe - Version 2.0.0.4389
17-2-5 21:25:46.0|Info|AppFolderInfo|Data directory is being overridden to [/share/CACHEDEV2_DATA/SONARR_CONFIG]
17-2-5 21:25:46.7|Fatal|ConsoleApp|EPIC FAIL!
[v2.0.0.4389] TinyIoC.TinyIoCResolutionException: Unable to resolve type: NzbDrone.Common.EnvironmentInfo.IRuntimeInfo —> TinyIoC.TinyIoCResolutionException: Unable to resolve type: NzbDrone.Mono.EnvironmentInfo.MonoRuntimeProvider —> System.TypeInitializationException: The type initializer for ‘NzbDrone.Common.EnvironmentInfo.RuntimeInfoBase’ threw an exception. —> System.IO.FileNotFoundException: Could not find file “”
at System.IO.Directory.InsecureGetCurrentDirectory () <0x7f0c4f54cb70 + 0x0003a> in :0
at System.IO.Directory.GetCurrentDirectory () <0x7f0c4f54cae0 + 0x0000c> in :0
at NzbDrone.Common.EnvironmentInfo.RuntimeInfoBase.InternalIsProduction () <0x410a72e0 + 0x001ea> in :0
at NzbDrone.Common.EnvironmentInfo.RuntimeInfoBase…cctor () <0x410a72b0 + 0x0000b> in :0
at NzbDrone.Mono.EnvironmentInfo.MonoRuntimeProvider…ctor (IServiceProvider serviceProvider, NLog.Logger logger) <0x410a70e0 + 0x0001f> in :0
at (wrapper dynamic-method) System.Object:lambda_method (System.Runtime.CompilerServices.Closure,object)
at TinyIoC.TinyIoCContainer.ConstructType (System.Type requestedType, System.Type implementationType, System.Reflection.ConstructorInfo constructor, TinyIoC.NamedParameterOverloads parameters, TinyIoC.ResolveOptions options) <0x4108c860 + 0x004a3> in :0
at TinyIoC.TinyIoCContainer.ConstructType (System.Type requestedType, System.Type implementationType, System.Reflection.ConstructorInfo constructor, TinyIoC.NamedParameterOverloads parameters, TinyIoC.ResolveOptions options) <0x4108c860 + 0x0051f> in :0
at TinyIoC.TinyIoCContainer.ConstructType (System.Type requestedType, System.Type implementationType, System.Reflection.ConstructorInfo constructor, TinyIoC.ResolveOptions options) <0x4108c800 + 0x00043> in :0
at TinyIoC.TinyIoCContainer+SingletonFactory.GetObject (System.Type requestedType, TinyIoC.TinyIoCContainer container, TinyIoC.NamedParameterOverloads parameters, TinyIoC.ResolveOptions options) <0x4108c630 + 0x000bf> in :0
at TinyIoC.TinyIoCContainer.ResolveInternal (TinyIoC.TypeRegistration registration, TinyIoC.NamedParameterOverloads parameters, TinyIoC.ResolveOptions options) <0x4108bc50 + 0x000bc> in :0
at TinyIoC.TinyIoCContainer+DelegateFactory.GetObject (System.Type requestedType, TinyIoC.TinyIoCContainer container, TinyIoC.NamedParameterOverloads parameters, TinyIoC.ResolveOptions options) <0x4108c4a0 + 0x00097> in :0
QSonarr refuses to start! Have tried several different versions of Qmono to no avail.
