Sonarr version (exact version): 3.0.3.698
Mono version (if Sonarr is not running on Windows):4.8.1
OS: Qnap
Debug logs: https://pastebin.com/J3A4d1uJ
Just upgrading after my front end stopped supporting v2.
The first time I imported my v2 backup and noticed none of my Indexers were connecting, assumed that the original backups weren’t supported, so deleted everything and started afresh.
First thing I’ve done on the fresh install is go to set up the new Indexer, Using using the NZBGeek preset, so I think the only thing I need to input is the API key, which I have double checked from the site. It just says “Unable to connect to indexer, check the log for more details” and I can’t make head or tail of the Logs.
Other strange things from when I imported my original config:
- Couldn’t send pushover test notifications.
- Can’t connect to check for updates.
Thanks.
