QBIT connection error
OS:
((Debug logs)):
Qbit was working fine, then yesterday, it stopped getting connection, any ideas?
NzbDrone.Core.Download.Clients.DownloadClientException: Failed to connect to qBitTorrent, please check your settings. —> NzbDrone.Common.Http.HttpException: HTTP request failed: [401:Unauthorized] [POST] at [http://localhost:9092/login]
at NzbDrone.Common.Http.HttpClient.Execute(HttpRequest request) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\HttpClient.cs:line 106
at NzbDrone.Core.Download.Clients.QBittorrent.QBittorrentProxy.AuthenticateClient(HttpRequestBuilder requestBuilder, QBittorrentSettings settings, Boolean reauthenticate) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrentProxy.cs:line 214
at NzbDrone.Core.Download.Clients.QBittorrent.QBittorrentProxy.AuthenticateClient(HttpRequestBuilder requestBuilder, QBittorrentSettings settings, Boolean reauthenticate) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrentProxy.cs:line 224
at NzbDrone.Core.Download.Clients.QBittorrent.QBittorrentProxy.ProcessRequest[TResult](HttpRequestBuilder requestBuilder, QBittorrentSettings settings) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrentProxy.cs:line 156
at NzbDrone.Core.Download.Clients.QBittorrent.QBittorrentProxy.GetVersion(QBittorrentSettings settings) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrentProxy.cs:line 45
at NzbDrone.Core.Download.Clients.QBittorrent.QBittorrent.TestConnection() in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrent.cs:line 202: Failed to connect to qBitTorrent, please check your settings.
You updated qbit to 3.3.13 which is broken for anyone using the API: Search results for 'qbittorrent order:latest' - sonarr :: forums
