Pushover Connector not following settings
I’ve got Pushover setup and working in the Connect section. The only little glitch is that I’ve set the priority to silent (-1), but the notifications are coming through as normal (0).
A work around is to set the Sound to “none”. So it does work as I want it to, but I have to use a workaround. Thought the devs might want to know.
I’m not seeing this behavior when testing, the proper value (-1) is stored in the database and used when sending. When you go to settings is it set to Quiet or Normal?
It’s set to Quiet. But the text notification as well as the event notifications produce a chime… Odd…
I’ll take a look at the app and the web panel. I don’t remember if there’s a way to override a priority setting there, but I’ll take a look.
