Pushbullet Notifications on iOS Missing Episode Info
I searched but didn’t find any recent comments on this.
I’m trying the Pushbullet notification system with Sonarr and although it does seem to work as intended, it doesn’t show any info in the notification (like the series name and episode number). It just tells you “Episode Downloaded”.
Am I missing a setting somewhere that would add this info? It doesn’t seem very useful if you have to open your device and open the app to see what downloaded.
I liked Pushover but it just completely stopped working for me and I thought I’d try Pushbullet.
The header just shows Sonarr - Episode Downloaded, but the body shows the full series and episode info.
Thanks for the reply. I was thinking that it was expected behavior but thought I’d check.
I use a smartwatch and it would be so much better if instead of:
“Sonarr - Episode Downloaded”
It gave:
“The Goldbergs-S02E23 Downloaded”
Not many more characters but far more useful.
The ability to customize them is something we want to add:
