Problems with folders and file recognition
Mono version (if Sonarr is not running on Windows): None
OS: Windows 10
Debug logs: missing root folder z:\plex\tv
Description of issue: Sonarr not recognizing files already downloaded
Sabnzbd and Sonarr runs on my Windows desktop.
Synology diskstation stores all TV shows
Whats happening:
Sonarr is able to communicate with Sabnzbd and my indexer to download the right TV shows
After download, Sabnzbd moves it to Z:\PLEX\TV
From then on Sonarr doesn’t realize that the TV Show has been downloaded.
Under series it still records as 0/1 for the season for example.
Hence it doesn’t rename or move them anywhere (this is a later problem).
However for some other shows, it does recognize existing files and i get 10/10 for the season.
This causes SONARR to continuously download some episodes as they come live on the indexer (or so i believe).
This is a file naming problem, what exact folders should SABNZBD be downloading to, how does SONARR reference that folder and how do i name folders in the series editor?
In addition, what is Root folder? Where is it really used? Do all shows have the same root folder e.g. Z:\PLEX\TV and we leave it as that? I get an error “path is already configured as a root folder” when i try doing that for individual shows.
I’ve tried searching around the help files.
Any help is appreciated thank you.
