Hi
I am using HP Microserver gen 8 with Windows home server 2011. worked perfectly for a year, now no longer.
when I try to add SABnzbd I get error Problems setting up download client (SABnzbd) - Test was aborted due to an error: Cannot combine OsPaths of different platforms (‘C:\Users\Administrator\Documents’ + ‘Downloads/complete’)
Log shows this
Invalid request Validation failed:
– Test was aborted due to an error: Cannot combine OsPaths of different platforms (‘C:\Users\Administrator\Documents’ + ‘Downloads/complete’)
please help
thanks
Roy
I think it has something to do with the path format you have configured in sab. Can you update the path in sab to downloads\completed and see if it fixes it. If it does we should probably handle it better.
Hi
Ok, thanks for the help guys, I am obviously just not getting it, Sorry for being so stupid but I just cannot get it to work, spent so many hours now I think I am just giving up on this,
Roy
Fixed for him, was from the / instead of \ in his path,
seems to be a sanbznd bug on his Windows Home Server 2011 or something weird with his sabnzbd.ini - was unable to change the paths, path would just revert back to what is was originally.after saving/restarting sabnzbd
had to change paths manually in sabnzbd.ini for him, then it was fine
Wasnt a permissions issue as could change other settings and it would write it to the ini, just not the paths.
Thank you Dan, Dan did in 15 minutes what I had been trying to do for hours and hours- thank you so much for your time and knowledge ( and tips for my server).
What a guy!
K
