Hey,
It looks like sonarr has problems downloading animes?
I have uTorrent as downloader configured and it is working i just downloaded something.
Only when it comes to anime i run into problems.
RssSyncService RSS Sync Completed. Reports found: 212, Reports grabbed: 0 11:26am
EpisodeSearchService Episode search completed. 0 reports downloaded. 11:25am
DownloadDecisionMaker No results found 11:25am
NzbSearchService Searching 3 indexers for [Naruto Shippuden : S17E54] 11:25am
DownloadDecisionMaker Processing 212 releases 11:25am
RssSyncService Starting RSS Sync 11:25am
Rarbg Indexer API call returned an error [Cant find search_tvdb in database. Are you sure this imdb exists?] - https://torrentapi.org/pubapi.php?mode=search&search_tvdb=291630&search_string=S01E01&ranked=0&category=18;41&limit=100&token=&format=json_extended&response_type=json: Indexer API call returned an error [Cant find search_tvdb in database. Are you sure this imdb exists?] 11:24am
NzbSearchService Searching 3 indexers for [The Heroic Legend of Arslan (2015) : S01E01] 11:24am
Rarbg Indexer API call returned an error [Cant find search_tvdb in database. Are you sure this imdb exists?] - https://torrentapi.org/pubapi.php?mode=search&search_tvdb=289882&search_string=S01E11&ranked=0&category=18;41&limit=100&token=&format=json_extended&response_type=json: Indexer API call returned an error [Cant find search_tvdb in database. Are you sure this imdb exists?] 11:24am
NzbSearchService Searching 3 indexers for [Is It Wrong to Try to Pick Up Girls in a Dungeon? : S01E11] 11:24am
Do you understand this?
thanks
