Sonarr version (exact version): 2.0.0.5054 (Qsonarr)
Mono version (if Sonarr is not running on Windows): 5.4.1.6.0
OS: QTS 4.3.3.0378 (Qnap)
((Debug logs)):
17-12-11 16:48:55.2|Info|RssSyncService|Starting RSS Sync
17-12-11 16:48:55.2|Warn|FetchAndParseRssService|No available indexers. check your configuration.
17-12-11 16:48:55.3|Info|DownloadDecisionMaker|No results found
17-12-11 16:48:55.3|Info|RssSyncService|RSS Sync Completed. Reports found: 0, Reports grabbed: 0
17-12-11 17:04:13.9|Info|RssSyncService|Starting RSS Sync
17-12-11 17:04:15.4|Warn|FetchAndParseRssService|No available indexers. check your configuration.
17-12-11 17:04:16.7|Info|DownloadDecisionMaker|No results found
17-12-11 17:04:30.4|Info|RssSyncService|RSS Sync Completed. Reports found: 0, Reports grabbed: 0
17-12-11 17:18:50.6|Warn|Rarbg|Unable to connect to indexer
[v2.0.0.5054] System.Net.WebException: DNS Name Resolution Failure: 'torrentapi.org'
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x0015e] in <22414d89e85c45babce99539812a436f>:0
at NzbDrone.Common.Http.Dispatchers.FallbackHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x0003c] in <22414d89e85c45babce99539812a436f>:0
at NzbDrone.Common.Http.HttpClient.ExecuteRequest (NzbDrone.Common.Http.HttpRequest request) [0x0007e] in <22414d89e85c45babce99539812a436f>:0
at NzbDrone.Common.Http.HttpClient.Execute (NzbDrone.Common.Http.HttpRequest request) [0x00000] in <22414d89e85c45babce99539812a436f>:0
at NzbDrone.Common.Http.HttpClient.Get (NzbDrone.Common.Http.HttpRequest request) [0x00007] in <22414d89e85c45babce99539812a436f>:0
at NzbDrone.Common.Http.HttpClient.Get[T] (NzbDrone.Common.Http.HttpRequest request) [0x00000] in <22414d89e85c45babce99539812a436f>:0
at NzbDrone.Core.Indexers.Rarbg.RarbgTokenProvider+<>c__DisplayClass4_0.<GetToken>b__0 () [0x00084] in <65fd07448b304721a1cf8bbfea4394c9>:0
at NzbDrone.Common.Cache.Cached`1[T].Get (System.String key, System.Func`1[TResult] function, System.Nullable`1[T] lifeTime) [0x0006a] in <22414d89e85c45babce99539812a436f>:0
at NzbDrone.Core.Indexers.Rarbg.RarbgTokenProvider.GetToken (NzbDrone.Core.Indexers.Rarbg.RarbgSettings settings) [0x00044] in <65fd07448b304721a1cf8bbfea4394c9>:0
at NzbDrone.Core.Indexers.Rarbg.RarbgRequestGenerator+<GetPagedRequests>d__12.MoveNext () [0x0014a] in <65fd07448b304721a1cf8bbfea4394c9>:0
at System.Linq.Enumerable.TryGetFirst[TSource] (System.Collections.Generic.IEnumerable`1[T] source, System.Boolean& found) [0x00045] in <204ed983d593479a8dff85dd3269e1a1>:0
at System.Linq.Enumerable.First[TSource] (System.Collections.Generic.IEnumerable`1[T] source) [0x00000] in <204ed983d593479a8dff85dd3269e1a1>:0
at NzbDrone.Core.Indexers.HttpIndexerBase`1[TSettings].TestConnection () [0x0001f] in <65fd07448b304721a1cf8bbfea4394c9>:0
17-12-11 17:18:51.3|Warn|NzbDroneErrorPipeline|Invalid request Validation failed:
-- Unable to connect to indexer, check the log for more details
Whenever I try to configure an indexer I get a “Unable to connect to indexer, check the log for more details” message.
The log is above.
It looks like a DNS problem but I can curl to ‘torrentapi.org’ with no problems and have configured Google’s DNS servers on the system.
I can also use Qnap’s Download Station to search and download torrents ok which leads me to believe the issue is not DNS related.
I looked around the forum for similar issues but have found nothing that helped me.
Thanks for any help.
