you are indeed correct
# sqlite3 nzbdrone.db "PRAGMA integrity_check"
database disk image is malformed
then ran
# sqlite3 nzbdrone.db ".recover" | sqlite3 sonarrv3.db
# sqlite3 sonarrv3.db "PRAGMA integrity_check"
ok
then
cp sonarrv3.db /var/lib/sonarr/sonarr.db
different problem now
2021-09-29 02:05:08.4|Error|MigrationLogger|System.FormatException: String was not recognized as a valid DateTime.
at System.DateTimeParse.ParseExactMultiple (System.ReadOnlySpan`1[T] s, System.String[] formats, System.Globalization.DateTimeFormatInfo dtfi, System.Globalization.DateTimeStyles style) [0x0002f] in <12b418a7818c4ca0893feeaaf67f1e7f>:0
at System.DateTime.ParseExact (System.String s, System.String[] formats, System.IFormatProvider provider, System.Globalization.DateTimeStyles style) [0x00025] in <12b418a7818c4ca0893feeaaf67f1e7f>:0
at System.Data.SQLite.SQLiteConvert.ToDateTime (System.String dateText, System.Data.SQLite.SQLiteDateFormats format, System.DateTimeKind kind, System.String formatString) [0x000f9] in <61a20cde294d4a3eb43b9d9f6284613b>:0
at System.Data.SQLite.SQLiteConvert.ToDateTime (System.String dateText) [0x00000] in <61a20cde294d4a3eb43b9d9f6284613b>:0
at System.Data.SQLite.SQLiteConvert.ToDateTime (System.IntPtr ptr, System.Int32 len) [0x00009] in <61a20cde294d4a3eb43b9d9f6284613b>:0
at System.Data.SQLite.SQLite3.GetDateTime (System.Data.SQLite.SQLiteStatement stmt, System.Int32 index) [0x00079] in <61a20cde294d4a3eb43b9d9f6284613b>:0
at System.Data.SQLite.SQLiteDataReader.GetDateTime (System.Int32 i) [0x00034] in <61a20cde294d4a3eb43b9d9f6284613b>:0
at NzbDrone.Core.Datastore.Migration.add_download_history.InitialImportedDownloadHistory (System.Data.IDbConnection conn, System.Data.IDbTransaction tran) [0x00047] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Datastore\Migration\139_add_download_history.cs:61
at FluentMigrator.Runner.Processors.SQLite.SQLiteProcessor.Process (FluentMigrator.Builders.Execute.PerformDBOperationExpression expression) [0x00038] in <137fb96feee44f379d6a8fba4e172d1c>:0
at FluentMigrator.Builders.Execute.PerformDBOperationExpression.ExecuteWith (FluentMigrator.IMigrationProcessor processor) [0x00000] in <c16130ff2bfb4746b4fb36de17115e3e>:0
at FluentMigrator.Runner.MigrationRunner+<>c__DisplayClass72_0.<ExecuteExpressions>b__1 () [0x00011] in <137fb96feee44f379d6a8fba4e172d1c>:0
at FluentMigrator.Runner.StopWatch.Time (System.Action action) [0x00006] in <137fb96feee44f379d6a8fba4e172d1c>:0
at FluentMigrator.Runner.MigrationRunner.AnnounceTime (System.String message, System.Action action) [0x0000c] in <137fb96feee44f379d6a8fba4e172d1c>:0
at FluentMigrator.Runner.MigrationRunner.ExecuteExpressions (System.Collections.Generic.ICollection`1[T] expressions) [0x0006c] in <137fb96feee44f379d6a8fba4e172d1c>:0
[v3.0.6.1265] System.FormatException: String was not recognized as a valid DateTime.
2021-09-29 02:05:08.7|Fatal|ConsoleApp|EPIC FAIL!
at FluentMigrator.Runner.MigrationRunner.ExecuteExpressions (System.Collections.Generic.ICollection`1[T] expressions) [0x000a5] in <137fb96feee44f379d6a8fba4e172d1c>:0
at FluentMigrator.Runner.MigrationRunner.ExecuteMigration (FluentMigrator.IMigration migration, System.Action`2[T1,T2] getExpressions) [0x0005a] in <137fb96feee44f379d6a8fba4e172d1c>:0
at FluentMigrator.Runner.MigrationRunner.ApplyMigrationUp (FluentMigrator.Infrastructure.IMigrationInfo migrationInfo, System.Boolean useTransaction) [0x0010f] in <137fb96feee44f379d6a8fba4e172d1c>:0
at FluentMigrator.Runner.MigrationRunner.MigrateUp (System.Boolean useAutomaticTransactionManagement) [0x000af] in <137fb96feee44f379d6a8fba4e172d1c>:0
at NzbDrone.Core.Datastore.Migration.Framework.MigrationController.Migrate (System.String connectionString, NzbDrone.Core.Datastore.Migration.Framework.MigrationContext migrationContext) [0x000a2] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Datastore\Migration\Framework\MigrationController.cs:51
at NzbDrone.Core.Datastore.DbFactory.CreateMain (System.String connectionString, NzbDrone.Core.Datastore.Migration.Framework.MigrationContext migrationContext) [0x0000b] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Datastore\DbFactory.cs:117
at NzbDrone.Core.Datastore.DbFactory.Create (NzbDrone.Core.Datastore.Migration.Framework.MigrationContext migrationContext) [0x00027] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Datastore\DbFactory.cs:82
at NzbDrone.Core.Datastore.DbFactory.Create (NzbDrone.Core.Datastore.Migration.Framework.MigrationType migrationType) [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Datastore\DbFactory.cs:70
at NzbDrone.Core.Datastore.DbFactory.RegisterDatabase (NzbDrone.Common.Composition.IContainer container) [0x00000] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Datastore\DbFactory.cs:48
at NzbDrone.Host.NzbDroneServiceFactory.Start () [0x00037] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Host\ApplicationServer.cs:60
at NzbDrone.Host.Router.Route (NzbDrone.Host.ApplicationModes applicationModes) [0x0007f] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Host\Router.cs:56
at NzbDrone.Host.Bootstrap.Start (NzbDrone.Host.ApplicationModes applicationModes, NzbDrone.Common.EnvironmentInfo.StartupContext startupContext) [0x0003d] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Host\Bootstrap.cs:78
at NzbDrone.Host.Bootstrap.Start (NzbDrone.Common.EnvironmentInfo.StartupContext startupContext, NzbDrone.Host.IUserAlert userAlert, System.Action`1[T] startCallback) [0x0007f] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Host\Bootstrap.cs:41
at NzbDrone.Console.ConsoleApp.Main (System.String[] args) [0x00030] in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Console\ConsoleApp.cs:42
2021-09-29 02:05:11.8|Info|Bootstrap|Starting Sonarr - /usr/lib/sonarr/bin/Sonarr.exe - Version 3.0.6.1265
2021-09-29 02:05:12.9|Info|AppFolderInfo|Data directory is being overridden to [/var/lib/sonarr]
2021-09-29 02:05:13.8|Info|Router|Application mode: Interactive
2021-09-29 02:05:14.3|Info|MigrationLogger|*** Checking database for required migrations data source=/var/lib/sonarr/sonarr.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
2021-09-29 02:05:14.8|Info|MigrationLogger|*** 139: add_download_history migrating ***
2021-09-29 02:05:14.8|Info|add_download_history|Starting migration to 139
there seems to be progress probably hindered by some date format issue?
