Problem with Torrents not being moved
Im not sure if this is how its supposed to be but for some reason torrents never clear from the activity and I think for that reason they are not being processed. I have about 100 torrents in activity that all still say downloading even though they are finished and i was able to manual extract and sort to the folder i needed it to be in. I have torrents download to /Torrents folder and after completion they are supposed to move to /Completed which is the folder i have set under the drone factory but it seems like the file never gets moved because they never technically finish according to sonarr? Maybe im way off but this is the same way i have newsgroups setup and that finishes and moves to /Completed and works perfectly. Its probably something simple im over looking. Thanks in advance.
Sonarr will show why its not importing them right on Activity: Queue (hover over the icon on the left). Debug logs would also be useful.
