Problem with series page created for "The Knick (2014)"
I have added the new series “The Knick” and the page is generated, but it contains no information other than the title. and a small box pops up in the lower right hand corner of my screen with this message “constraint failed UNIQUE constraint failed: Series, TitleSlug”. Also, the show does not show up in the calendar nor does it download after it airs. Any help with this problem would be greatly appreciated. Thanks
Which version of drone?
Which OS?
And we need log files: https://github.com/NzbDrone/NzbDrone/wiki/Log-Files
Sorry about that, I thought the error message would tell you what you needed to know. My OS: Win7, Drone version: 2.0.0.1690, and I was trying to figure out the whole log file thing so I set the logging to debug and went back to try and recreate the problem. I tried refreshing the series but I only got a pop-up saying “refresh failed” so I decided to delete the entry for the show and add it again. When I did, this time it worked. I think the difference between this time and the other times was this time I added it as “The Knick (2014)” instead of simply “The Knick”. Sorry for the noob post.
No problem, for next time, the UI messages generally have a backend error message that contains much more detail.
I suspect your issue was due to a change in IDs with tvdb/trakt that has since been resolved, so when you removed and re-added it you got the proper info from trakt and all it well again.
