Problem with Moving Processed File
Hi, I’m new to Sonarr, a not very tech-y Grandma, but hoping this question has a simple answer.
I previously setup using Sickbeard/SAB. Today I decided to try Sonarr, continuing to use SAB as my download client. I have a Watched Folder setup in SAB called NZB to SAB where NZB’s are downloaded, and a separate Completed Download File (also setup in SAB) where the completed processed files are moved.
Sonaar downloads and processes my NZB’s, but leaves them in that NZB to SAB file, despite the fact that I still have SAB set up to move completed files to that separate Completed Downloaded file.
I hope this makes at least a little sense. Obviously, I want the files moved after processing, and not left in the Watched Folder.
Thanks!
We require some additional information about your setup to help determine the issue.
OS:
((Debug logs)):
Sonarr doesn’t deal with NZB files directly, do you mean the completed downloads?
Once SAB has moved the file Sonarr will move it to the series folder set for the series (set when adding the series), if that’s not the correct location you can edit the series (or use the Series Editor to make bulk changes) and fix the location.
TV sorting in SAB should be disabled and not relied on.
