Sonarr is unable to connect to indexer when trying to add RARBG tracker as an indexer. I’m on OS X El Capitan, running latest Mono and latest Sonarr build in master.
Ehat do the log files show?
Is curl available on your system?
I have not manually installed curl so that could be the issue. Error message is below:
15-11-1 22:27:34.0|Warn|Rarbg|Unable to connect to indexer: String was not recognized as a valid DateTime because the day of week was incorrect.
System.FormatException: String was not recognized as a valid DateTime because the day of week was incorrect.
at System.DateTimeParse.Parse (System.String s, System.Globalization.DateTimeFormatInfo dtfi, DateTimeStyles styles) [0x00026] in /private/tmp/source-mono-mac-4.0.0-bug-33585-hotfix/bockbuild-mono-4.0.0-branch/profiles/mono-mac-xamarin/build-root/mono-4.0.4/external/referencesource/mscorlib/system/globalization/datetimeparse.cs:2250
at System.DateTime.Parse (System.String s, IFormatProvider provider) [0x00000] in /private/tmp/source-mono-mac-4.0.0-bug-33585-hotfix/bockbuild-mono-4.0.0-branch/profiles/mono-mac-xamarin/build-root/mono-4.0.4/external/referencesource/mscorlib/system/datetime.cs:1070
at System.Convert.ToDateTime (System.String value) [0x0000e] in /private/tmp/source-mono-mac-4.0.0-bug-33585-hotfix/bockbuild-mono-4.0.0-branch/profiles/mono-mac-xamarin/build-root/mono-4.0.4/external/referencesource/mscorlib/system/convert.cs:1727
at NzbDrone.Common.Http.Dispatchers.CurlHttpDispatcher.<FixSetCookieHeader>b__7 (System.Text.RegularExpressions.Match match) [0x00006] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\Dispatchers\CurlHttpDispatcher.cs:179
at System.Text.RegularExpressions.RegexReplacement.Replace (System.Text.RegularExpressions.MatchEvaluator evaluator, System.Text.RegularExpressions.Regex regex, System.String input, Int32 count, Int32 startat) [0x000b4] in /private/tmp/source-mono-mac-4.0.0-bug-33585-hotfix/bockbuild-mono-4.0.0-branch/profiles/mono-mac-xamarin/build-root/mono-4.0.4/external/referencesource/System/regex/system/text/regularexpressions/RegexReplacement.cs:293
at System.Text.RegularExpressions.Regex.Replace (System.String input, System.Text.RegularExpressions.MatchEvaluator evaluator, Int32 count, Int32 startat) [0x00011] in /private/tmp/source-mono-mac-4.0.0-bug-33585-hotfix/bockbuild-mono-4.0.0-branch/profiles/mono-mac-xamarin/build-root/mono-4.0.4/external/referencesource/System/regex/system/text/regularexpressions/Regex.cs:1105
at System.Text.RegularExpressions.Regex.Replace (System.String input, System.Text.RegularExpressions.MatchEvaluator evaluator) [0x00011] in /private/tmp/source-mono-mac-4.0.0-bug-33585-hotfix/bockbuild-mono-4.0.0-branch/profiles/mono-mac-xamarin/build-root/mono-4.0.4/external/referencesource/System/regex/system/text/regularexpressions/Regex.cs:1069
at NzbDrone.Common.Http.Dispatchers.CurlHttpDispatcher.FixSetCookieHeader (System.String setCookie) [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\Dispatchers\CurlHttpDispatcher.cs:176
at NzbDrone.Common.Http.Dispatchers.CurlHttpDispatcher.ProcessHeaderStream (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies, System.IO.Stream headerStream) [0x0009d] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\Dispatchers\CurlHttpDispatcher.cs:167
at NzbDrone.Common.Http.Dispatchers.CurlHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x001b2] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\Dispatchers\CurlHttpDispatcher.cs:118
at NzbDrone.Common.Http.Dispatchers.FallbackHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x000aa] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\Dispatchers\FallbackHttpDispatcher.cs:51
at NzbDrone.Common.Http.HttpClient.Execute (NzbDrone.Common.Http.HttpRequest request) [0x00081] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\HttpClient.cs:70
at NzbDrone.Common.Http.HttpClient.Get (NzbDrone.Common.Http.HttpRequest request) [0x00007] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\HttpClient.cs:188
at NzbDrone.Common.Http.HttpClient.Get[JObject] (NzbDrone.Common.Http.HttpRequest request) [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\HttpClient.cs:193
at NzbDrone.Core.Indexers.Rarbg.RarbgTokenProvider+<>c__DisplayClass1.<GetToken>b__0 () [0x00028] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\Rarbg\RarbgTokenProvider.cs:33
at NzbDrone.Common.Cache.Cached`1[System.String].Get (System.String key, System.Func`1 function, Nullable`1 lifeTime) [0x00060] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Cache\Cached.cs:87
at NzbDrone.Core.Indexers.Rarbg.RarbgTokenProvider.GetToken (NzbDrone.Core.Indexers.Rarbg.RarbgSettings settings) [0x00014] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\Rarbg\RarbgTokenProvider.cs:29
at NzbDrone.Core.Indexers.Rarbg.RarbgRequestGenerator+<GetPagedRequests>d__0.MoveNext () [0x00110] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\Rarbg\RarbgRequestGenerator.cs:89
at System.Linq.Enumerable.First[IndexerRequest] (IEnumerable`1 source) [0x00032] in /private/tmp/source-mono-mac-4.0.0-bug-33585-hotfix/bockbuild-mono-4.0.0-branch/profiles/mono-mac-xamarin/build-root/mono-4.0.4/mcs/class/System.Core/System.Linq/Enumerable.cs:839
at NzbDrone.Core.Indexers.HttpIndexerBase`1[NzbDrone.Core.Indexers.Rarbg.RarbgSettings].TestConnection () [0x0000e] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:290
15-11-1 22:27:34.0|Warn|NzbDroneErrorPipeline|Invalid request Validation failed:
-- Unable to connect to indexer, check the log for more details
I do have curl installed apparently, version is as follows:
libcurl/7.43.0 SecureTransport zlib/1.2.5
Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps pop3 pop3s rtsp smb smbs smtp smtps telnet tftp
Features: AsynchDNS IPv6 Largefile GSS-API Kerberos SPNEGO NTLM NTLM_WB SSL libz UnixSockets
This error should be fixed in the latest develop releases and will be included in the next release.
@markus101 Thanks. I can confirm for anyone else facing the issue that the RARBG indexer is working as of the recent 2.0.0.3572 maintenance release.
