Problem with certain results at Kickass.to
Hi,
I’ve added the series The Flash and Marvel’s Agent Carter with 1080p web dl profile.
However, although I see the releases in kickass.to, they are not displayed in the manual search.
You can have a look at The Flash S01E13
Thanks.
I can’t even get kickass.to to work. When I changed it from .so to .to and tested the indexer, I receive the following error in the log: Invalid request Validation failed:
– No results were returned from your indexer, please check your settings.
They probably aren’t verified releases, so turn verification off in Sonarr’s KAT settings (there are a few threads on that here).
Please don’t hijack a thread for your own unrelated issues. Try a proxy URL, it may be blocked by your ISP (see the KAT changed addresses thread).
How do you verify the release?
BTW Agent Carter latest episode was successfully grabbed just now, so its just The Flash now.
Is NTB not a valid release group? or is the [rarbg] a problem?
I don’t know how they are verified, that’s specific to KAT.
