Problem when grabbing a full season
Hi, on Sonarr actually I’ve a problem with Santa Clarita Diet
I’ve only one episode S02e01 downloaded.
If I tell to sonarr to search for it I found strange logs, for example
18-3-24 21:14:03.5|Debug|DownloadDecisionMaker|Processing release 'Santa Clarita Diet S02e01-10 [Mux 1080p - H264 - Ita Eng Ac3 5.1 - Sub Ita Eng] By Morpheus [CURA] Mostri nella Storia' from 'TNT Village'
18-3-24 21:14:03.5|Debug|Parser|Parsing string 'Santa Clarita Diet S02e01-10 [Mux 1080p - H264 - Ita Eng Ac3 5.1 - Sub Ita Eng] By Morpheus [CURA] Mostri nella Storia'
18-3-24 21:14:03.5|Debug|Parser|Episode Parsed. Santa Clarita Diet - S02E01-02-03-04-05-06-07-08-09-10
18-3-24 21:14:03.5|Debug|Parser|Language parsed: Italian
18-3-24 21:14:03.5|Debug|QualityParser|Trying to parse quality for Santa Clarita Diet S02e01-10 [Mux 1080p - H264 - Ita Eng Ac3 5.1 - Sub Ita Eng] By Morpheus [CURA] Mostri nella Storia
18-3-24 21:14:03.5|Debug|Parser|Quality parsed: HDTV-1080p v1
18-3-24 21:14:03.5|Debug|Parser|Release Group parsed:
18-3-24 21:14:03.5|Debug|AcceptableSizeSpecification|Beginning size check for: Santa Clarita Diet S02e01-10 [Mux 1080p - H264 - Ita Eng Ac3 5.1 - Sub Ita Eng] By Morpheus [CURA] Mostri nella Storia
18-3-24 21:14:03.5|Debug|AcceptableSizeSpecification|Item: Santa Clarita Diet S02e01-10 [Mux 1080p - H264 - Ita Eng Ac3 5.1 - Sub Ita Eng] By Morpheus [CURA] Mostri nella Storia, meets size constraints.
18-3-24 21:14:03.5|Debug|CutoffSpecification|Comparing file quality with report. Existing file is HDTV-1080p v1
18-3-24 21:14:03.5|Debug|MaximumSizeSpecification|Maximum size is not set.
18-3-24 21:14:03.5|Debug|LanguageSpecification|Checking if report meets language requirements. Italian
18-3-24 21:14:03.5|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: Santa Clarita Diet S02e01-10 [Mux 1080p - H264 - Ita Eng Ac3 5.1 - Sub Ita Eng] By Morpheus [CURA] Mostri nella Storia
18-3-24 21:14:03.6|Debug|ReleaseRestrictionsSpecification|[Santa Clarita Diet S02e01-10 [Mux 1080p - H264 - Ita Eng Ac3 5.1 - Sub Ita Eng] By Morpheus [CURA] Mostri nella Storia] No restrictions apply, allowing
18-3-24 21:14:03.6|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. HDTV-1080p v1
18-3-24 21:14:03.6|Debug|MinimumAgeSpecification|Not checking minimum age requirement for non-usenet report
18-3-24 21:14:03.6|Debug|RetentionSpecification|Not checking retention requirement for non-usenet report
18-3-24 21:14:03.6|Debug|UpgradeDiskSpecification|Comparing file quality with report. Existing file is HDTV-1080p v1
18-3-24 21:14:03.6|Debug|SeriesSpecification|Checking if series matches searched series
18-3-24 21:14:03.6|Debug|DelaySpecification|Ignoring delay for user invoked search
18-3-24 21:14:03.6|Debug|HistorySpecification|Skipping history check during search
18-3-24 21:14:03.6|Debug|DownloadDecisionMaker|Release rejected for the following reasons: [Permanent] Quality for existing file on disk is of equal or higher preference: HDTV-1080p v1
Seems found and correctly recognized but Sonarr think that I’ve all season on disk and not, am I right?
here the full log
http://s000.tinyupload.com/index.php?file_id=03796242949478632033
Sonarr won’t grab aseason pack if one or more episodes already exists and the season pack is not a viable upgrade because the cutoff has already been metfor that one file or the quality is the same.
Ouch, not possible to put in download only the missing files or upgrade the lower quality?
I don’t know way but already happen 2 or 3 times, one file downloaded and so no full season grabbed
So 2 questions:
  1. If no full season are found, sonarr try to find each episode, right?
  2. Is possible (if have sense) automatically force a season download if one or more file are missing or in lower quality?
J
  1. Sonarr processes the results the indexers return if those include individual episodes they will be processed as well. It does not fallback to an explicit search for each episode
  2. Manual search is the only way to force something once the results have been processed, but that isn’t available for season searches. You could manually add the torrent/NZB to your client in the correct category and Sonarr will process it, remove the existing file or change the quality so the cutoff isn’t met.
