Sonarr version (exact version): 2.0.0.5322
Mono version (if Sonarr is not running on Windows):3.10.0
OS: Raspbian 9.9
Hello, I have a question because I’m Testing it and I don’t sure if I have a bug or I’m doing something bad.
On my installation, I’m running Jackett in order to get torrents on one tracker “mejortorrent”. I have connected it, and then, I’m going to search a serie as for example “La que se avecina” that has 11 seasons. The tracker Mejortorrent has seasons include the live season 11. From Sonarr is only available 10 seasons. The 11 season isn’t found by sonarr. I have tried to search it from Jackett and It shows them. So, What is reason that sonarr can’t find season 11?
Other case, I would like to see the “supernatural” that have 14 seasons, and I have found it on tracker and is available. I have tried to download it from Sonarr and Sonarr can’t find torrent on tracker. What happen? I think that it is a good project but I don’t understand what is the reason that it doesn’t work.? is the language? On Sonnar the serie is called “supernatural” and the tracker is “sobrenatural”.
Thank you
