Mono version (if Sonarr is not running on Windows): 5.18.0.225
OS: Linux Mint
I Search Indexer for “Dragon Ball 052”
Results include:
[PENDEKAR] DRAGON BALL - 052 [DRAGON BOX] [DUAL AUDIO]
Open Sonarr Series “Dragon Ball” S3E24 (Absolute 52)
Manual Search reveals 14 results (all rejected)
but the Title above does not show up!
Among the Results –
Dragon.Ball.Z.Kai.-.52.x264-AACDual.AudioC-W
235.4 MB SDTV
Release Rejected
Episode wasn’t requested: 1x52
Wrong series
Dragon.Ball.Z.Kai.-.52.CutC-W
206.7 MB Unknown
Release Rejected
Unknown is not wanted in profile
Wrong series
[Desidis].Dragon.Ball.GT.52.[DVD.768x576.H264.10Bit.AC3]
986.6 MB DVD
Release Rejected
Episode wasn’t requested: 3x12
Wrong series
[BudLightSubs].Dragon.Ball.Super.-.52.[720p]
612.2 MB HDTV-720p
Release Rejected
Episode wasn’t requested: 4x6
Wrong series
If I download the nzb from the Indexer and in Sonarr Wanted > Manual Import I see:
[Pendekar] Dragon Ball - 052 [Dragon Box] [Dual Audio]/[Pendekar] Dragon Ball - 052 [Dragon Box] [Dual Audio].mkv
Dragon Ball 3 24 SDTV 899.1 MB
If I check check the box and Import, sucess.
** It appears Sonarr can Import this release with no problem, including mapping the Season/Episode from the Absolute Episode. Why is it not even showing up in Manual Search or importing Automatically?? **
Here are all the relevant settings (I hope. Let me know if you need more). Thanks.
Series Settings–
Monitored: Yes
Use Season Folder: Yes
Profile: Anime
Series Type Anime
Path (/-valid library path-)
Tags: (None)
(Only Active) Indexer–
Categories: 5020,5030,5040,5050,5070,5080
Anime Categories: 5070
Indexers > Restrictions: (None)
Profiles–
Language: English
Cutoff: Unknown
Qualities:
*SDTV
*DVD
*HDTV-720p
*Unkown
Quality (Min/Max Size for 30 minute episode) –
Unkown: 60MB - 2GB
SDTV: 60MB - 2GB
WEBDL-480: 60MB - 2GB
DVD: 60MB - 2GB
HDTV-720p: 60MB - 2GB
