Hello everyone,
I have an issue I’ve been struggling with for some time. I googled around quite a bit but none of the suggestions in threads for similar issues seem to work for me.
The issue is that Sonarr ends up redownloading episodes that have already been downloading in the past. I would like it to download a new episode according to the quality criteria I set, and once this episode has been downloaded once, never to be downloaded again, period.
My setup is such that episodes are downloaded on a Debian server (where Sonarr and Rutorrent are installed), then once the download is complete, it is synced to a BSD server where I store them, then deleted from the Debian server within the hour after it was downloaded. So from Sonarr’s perspective, all episodes downloaded are then deleted within the hour.
I have tried to set up my settings properly.
Ignoring deleted episodes and disabling downloads of propers:
Setting up lowest quality cutoff within the profile so better quality versions are not downloaded:
But as you can see Sonarr keeps on redownloading same episodes, here are the last three examples:
My assumption was that with the “Ignore deleted episodes” setting toggled on, episodes deleted would be unmonitored and appear as such, but it doesn’t seem to work that way, not sure if that’s intended or a bug, they remain monitored even after deletion:
Here is the debug log from that last redownload:
19-8-26 02:07:56.7|Debug|DownloadDecisionMaker|Processing release 'Preacher.S04E05.Bleak.City.1080p.AMZN.WEBRip.DDP5.1.x264-NTG[rartv]' from 'Rarbg'
19-8-26 02:07:56.7|Debug|Parser|Parsing string 'Preacher.S04E05.Bleak.City.1080p.AMZN.WEBRip.DDP5.1.x264-NTG[rartv]'
19-8-26 02:07:56.7|Debug|Parser|Episode Parsed. Preacher - S04E05
19-8-26 02:07:56.7|Debug|Parser|Language parsed: English
19-8-26 02:07:56.7|Debug|QualityParser|Trying to parse quality for Preacher.S04E05.Bleak.City.1080p.AMZN.WEBRip.DDP5.1.x264-NTG[rartv]
19-8-26 02:07:56.7|Debug|Parser|Quality parsed: WEBDL-1080p v1
19-8-26 02:07:56.7|Debug|Parser|Release Group parsed: NTG
19-8-26 02:07:56.7|Debug|AlreadyImportedSpecification|Performing alerady imported check on report
19-8-26 02:07:56.7|Debug|AlreadyImportedSpecification|Skipping already imported check for episode without file
19-8-26 02:07:56.7|Debug|AcceptableSizeSpecification|Beginning size check for: Preacher.S04E05.Bleak.City.1080p.AMZN.WEBRip.DDP5.1.x264-NTG[rartv]
19-8-26 02:07:56.7|Debug|AcceptableSizeSpecification|Item: Preacher.S04E05.Bleak.City.1080p.AMZN.WEBRip.DDP5.1.x264-NTG[rartv], meets size constraints.
19-8-26 02:07:56.7|Debug|MaximumSizeSpecification|Maximum size is not set.
19-8-26 02:07:56.7|Debug|LanguageSpecification|Checking if report meets language requirements. English
19-8-26 02:07:56.7|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: Preacher.S04E05.Bleak.City.1080p.AMZN.WEBRip.DDP5.1.x264-NTG[rartv]
19-8-26 02:07:56.7|Debug|ReleaseRestrictionsSpecification|[Preacher.S04E05.Bleak.City.1080p.AMZN.WEBRip.DDP5.1.x264-NTG[rartv]] No restrictions apply, allowing
19-8-26 02:07:56.7|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. WEBDL-1080p v1
19-8-26 02:07:56.7|Debug|MinimumAgeSpecification|Not checking minimum age requirement for non-usenet report
19-8-26 02:07:56.7|Debug|RetentionSpecification|Not checking retention requirement for non-usenet report
19-8-26 02:07:56.7|Debug|DelaySpecification|Profile does not require a waiting period before download for Torrent.
19-8-26 02:07:56.7|Debug|HistorySpecification|Performing history status check on report
19-8-26 02:07:56.7|Debug|HistorySpecification|Checking current status of episode [2165] in history
19-8-26 02:07:56.7|Debug|DownloadDecisionMaker|Release accepted
19-8-26 02:07:56.7|Debug|DownloadDecisionMaker|Processing release 'Preacher.S04E05.Bleak.City.720p.AMZN.WEBRip.DDP5.1.x264-NTG[rartv]' from 'Rarbg'
19-8-26 02:07:56.7|Debug|Parser|Parsing string 'Preacher.S04E05.Bleak.City.720p.AMZN.WEBRip.DDP5.1.x264-NTG[rartv]'
19-8-26 02:07:56.7|Debug|QualityParser|Trying to parse quality for Preacher.S04E05.Bleak.City.720p.AMZN.WEBRip.DDP5.1.x264-NTG[rartv]
19-8-26 02:07:56.7|Debug|Parser|Quality parsed: WEBDL-720p v1
19-8-26 02:07:56.7|Debug|AcceptableSizeSpecification|Beginning size check for: Preacher.S04E05.Bleak.City.720p.AMZN.WEBRip.DDP5.1.x264-NTG[rartv]
19-8-26 02:07:56.7|Debug|AcceptableSizeSpecification|Item: Preacher.S04E05.Bleak.City.720p.AMZN.WEBRip.DDP5.1.x264-NTG[rartv], meets size constraints.
19-8-26 02:07:56.7|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: Preacher.S04E05.Bleak.City.720p.AMZN.WEBRip.DDP5.1.x264-NTG[rartv]
19-8-26 02:07:56.7|Debug|ReleaseRestrictionsSpecification|[Preacher.S04E05.Bleak.City.720p.AMZN.WEBRip.DDP5.1.x264-NTG[rartv]] No restrictions apply, allowing
19-8-26 02:07:56.7|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. WEBDL-720p v1
Happy to provide further log entries as needed, any help would be appreciated.
Thanks!
Mono version (if Sonarr is not running on Windows): 5.10.1.57
OS: Debian 9.8
