PostProcessing to network drive
Hello i just moved from SickBeard like so many others here :slight_smile:
But cant find how to configure this:
In SB i used SAB to download my series to de incomplete folder, after the dl it moved to the sickbeard folder (because of the TV category tag)
then SB does the post processing of renaming and moving to network drive (on my kodi pc)
Sonarr does not do this standard i gues?
Sonarr DL to incompleet folder and there it makes series.title folder and season folder, and all of the fanart etc.
But i like that to be on Y:\ or \GEBRUIK-L67TOAJ\Series (both same network drive on other pc)
How do i proceed. (i didnt use sabtosickbeard or what ever)
Keep up the good work.
(now i like to have an addon for kodi to see whats up and comming like a tv guide (same as calender in sonar)
Richard
Sonarr does post process files by default, take a look at the FAQ as there are some limitations in Windows when using a Mapped Network Drive.
i already have taken actions to use network drives (for scanning the series folder)
that works now.
were do i set the path of the processed files ?
Sonarr will automatically get the path from your download client and move it to the series folder (which was picked when adding the series to Sonarr).
I have it working now, but i noticed today that sabnzbd not moved some episodes to the processing folder after finishing a download, moved them manual and sonarr picked them up immidiatly, i had remove ON, so i couldnt see what was happening in SAB, now i have it off so we see what is happening when new episodes arive.
Part of all this is not understanding (yet) how sonarr is working :smile:
thanks so far.
I get:
Intermediate Download path inside drone factory, Skipping.
what does that mean ?
NCIS is not processed
Don’t set the drone factory folder to the same location or a parent of the path where SAB puts files. Sonarr will get the path from SAB and import automatically.
Drone factory folder is for dealing with stubborn file names or files from another source (not downloaded with SAB).
