My apologies if this is ‘effectively’ described elsewhere but I can’t find the exact answer.
Running version 2.0.0.5344 on Windows Server 2016
I’m trying to confirm the best settings for the following scenario.
Sonarr is on Server1 (specifically so internal access to file shares is not negatively impacted by VPN
Transmission Client on Server2 (specific for VPN traffic)
NZBget on Server3 (to run free of VPN layer)
Final landing zone for completed downloads, after post-processing on NAS.
Server1 and Server3 have symbolic links to the NAS locations for each category. Solution will likely solve each scenario however the scenario is this.
Sonarr has no issue sending the DL request to Transmission and keeping track of status. The problem is I’m not getting post-processing. I have set up Remote Path with the exact UNC path to the folder where Transmission drops the TV category download. On the Sonarr server, I have a symbolic link set to direct c:\TransTV to the aforementioned UNC path.
Obviously the desired result is to post-process the download and copy it to the correct path where the TV shows lay to rest permanently on the NAS. The path for each show is correct and exists via SYMLINK on the Sonarr server.
Am I approaching this correctly or is there a better, recommended method?
