hi,
I have some problems with file parsing in the Drone Factory folder.
The show is "Get Out Alive (2013)"
And here is the log
14-4-14 09:58:42.2|Debug|Parser|Parsing string 'Get.Out.Alive.2013.S01E05.720p.HDTV.x264-BAJSKORV’
14-4-14 09:58:42.2|Trace|Parser|^(?.+?)(?:(\W|)+S?(?(?<!\d+)\d{1,2}(?!\d+))(?:(?:\-|[ex]|\W[ex]|){1,2}(?\d{2,3}(?!\d+)))+)\W?(?!\\)
14-4-14 09:58:42.2|Debug|Parser|Episode Parsed. getoutalive2013 - S01E05
14-4-14 09:58:42.2|Debug|Parser|Language parsed: English
14-4-14 09:58:42.2|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for Get.Out.Alive.2013.S01E05.720p.HDTV.x264-BAJSKORV
14-4-14 09:58:42.2|Debug|Parser|Quality parsed: HDTV-720p
14-4-14 09:58:42.2|Debug|Parser|Release Group parsed: BAJSKORV
14-4-14 09:58:42.2|Debug|DownloadedEpisodesImportService|Get.Out.Alive.2013.S01E05.720p.HDTV.x264-BAJSKORV folder quality: HDTV-720p
14-4-14 09:58:42.2|Debug|DownloadedEpisodesImportService|Unknown Series Get.Out.Alive.2013.S01E05.720p.HDTV.x264-BAJSKORV
As you can see it is not finding the corresponding show (download was sent to NZBGet by nzbdrone).
I have tried with
’Get.Out.Alive.(2013).S01E05.720p.HDTV.x264-BAJSKORV’
'Get.Out.Alive.S01E05.720p.HDTV.x264-BAJSKORV’
Without any success.
I should mention that the show has multiple entries on TheTVDB
http://www.thetvdb.com/?tab=series&id=270333&lid=14
http://www.thetvdb.com/?tab=series&id=208731&lid=7
But sadly the one linked by nzbdrone doesn’t seem to exist
http://www.thetvdb.com/?tab=series&id=271445
When added the show in NZBDrone there was 2 entries
Get Out Alive With Bear Grylls (2013)
I chose “Get Out Alive (2013)” because i new the scene release name would be “Get Out Alive (2013)” but apparently now it can’t rename it.
To your opinion is that just a scene name release problem?
If so i know you have a scene name request form, which is great. But i really think we would need a way to create aliases directly in NZBDrone. Right now i have to move/rename file manually :s
Thanks for your amazing work!
