Sonarr version (exact version): 3.0.3.652
OS: Win 10 pro
Just realized tags I created starting with numbers can’t be added to shows. For example, I had one called 2ch and it won’t show up in tags when I tried to add it to a show. The solution was simple- I just created tags in those profiles using words instead of numbers. But I thought I’d point it out. Could be a minor bug.
I can’t reproduce this issue. I created a new tag on a series that started with a number and also added that tag to another series and it attached to both without issue.
I wonder what I’m doing wrong?
- Created tag.
- Went to edit series
- Take doesn’t populate i list. If I manually type it and press save, it doesn’t stick.
- Other tags populate when I type them in.
5.1
isn’t a valid tag, numbers, letters and dashes are the only valid characters. We’ll have to improve the error messaging in that case.
Oh, I’ll be damned. I misidentified the problem. Thanks for taking the time!
