2.0.0.5338:
5.20.1:
linux/unraid:
Debug logs: below
As the title states. This occurred after about 1 year of working fine. Radarr continues to work fine. Once I reboot the server, all files are imported without issue from sonarr to Plex. I’ve done all the simple things, like Scan Library, Optimize Database, and of course make sure sonarr is set correctly — I’ve posted about this in the Plex forums and i was directed to post here for possible help.
Sonarr seems to be working fine otherwise.
Logs below. Any help would be appreciated
20-2-12 08:18:18.3|Trace|ConfigService|Using default config value for 'filedate' defaultValue:'None'
20-2-12 08:18:18.3|Trace|EventAggregator|ConfigFileSavedEvent <~ ReconfigureLogging
20-2-12 08:18:18.3|Trace|ConfigService|Using default config value for 'downloadclientworkingfolders' defaultValue:'_UNPACK_|_FAILED_'
20-2-12 08:18:18.3|Trace|ConfigService|Using default config value for 'downloadclienthistorylimit' defaultValue:'30'
20-2-12 08:18:18.3|Trace|ConfigService|Using default config value for 'skipfreespacecheckwhenimporting' defaultValue:'False'
20-2-12 08:18:18.3|Trace|ConfigService|Using default config value for 'copyusinghardlinks' defaultValue:'True'
20-2-12 08:18:18.3|Trace|ConfigService|Using default config value for 'enablemediainfo' defaultValue:'True'
20-2-12 08:18:18.3|Trace|ConfigService|Using default config value for 'importextrafiles' defaultValue:'False'
20-2-12 08:18:18.3|Trace|ConfigService|Using default config value for 'extrafileextensions' defaultValue:'srt'
20-2-12 08:18:18.3|Trace|ConfigService|Using default config value for 'setpermissionslinux' defaultValue:'False'
20-2-12 08:18:18.3|Trace|ConfigService|Using default config value for 'filechmod' defaultValue:'0644'
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'folderchmod' defaultValue:'0755'
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'chownuser' defaultValue:''
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'chowngroup' defaultValue:''
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'firstdayofweek' defaultValue:'1'
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'calendarweekcolumnheader' defaultValue:'ddd M/D'
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'shortdateformat' defaultValue:'MMM D YYYY'
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'longdateformat' defaultValue:'dddd, MMMM D YYYY'
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'timeformat' defaultValue:'h(:mm)a'
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'showrelativedates' defaultValue:'True'
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'enablecolorimpairedmode' defaultValue:'False'
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'proxyenabled' defaultValue:'False'
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'proxytype' defaultValue:'Http'
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'proxyhostname' defaultValue:''
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'proxyport' defaultValue:'8080'
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'proxyusername' defaultValue:''
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'proxypassword' defaultValue:''
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'proxybypassfilter' defaultValue:''
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'proxybypasslocaladdresses' defaultValue:'True'
20-2-12 08:18:18.4|Trace|EventAggregator|Publishing ConfigSavedEvent
20-2-12 08:18:18.4|Trace|EventAggregator|ConfigSavedEvent ~> TaskManager
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'downloadedepisodesfolder' defaultValue:''
20-2-12 08:18:18.4|Trace|ConfigService|Using default config value for 'rsssyncinterval' defaultValue:'15'
20-2-12 08:18:18.5|Trace|ConfigService|Using default config value for 'downloadedepisodesfolder' defaultValue:''
20-2-12 08:18:18.5|Trace|EventAggregator|ConfigSavedEvent <~ TaskManager
20-2-12 08:18:18.5|Trace|ConfigService|Using default config value for 'proxyhostname' defaultValue:''
20-2-12 08:18:18.5|Trace|ConfigService|Using default config value for 'proxyport' defaultValue:'8080'
20-2-12 08:18:18.5|Trace|ConfigService|Using default config value for 'proxyusername' defaultValue:''
20-2-12 08:18:18.5|Debug|SabnzbdProxy|Url: http://192.168.1.35:8181/api?mode=get_config&apikey=(removed)&output=json
20-2-12 08:18:18.5|Trace|ConfigService|Using default config value for 'proxypassword' defaultValue:''
20-2-12 08:18:18.5|Trace|HttpClient|Req: [GET] http://192.168.1.35:8181/api?mode=get_config&apikey=(removed)&output=json
20-2-12 08:18:18.5|Trace|ConfigService|Using default config value for 'proxybypassfilter' defaultValue:''
20-2-12 08:18:18.5|Trace|ConfigService|Using default config value for 'proxyenabled' defaultValue:'False'
20-2-12 08:18:18.5|Trace|ConfigService|Using default config value for 'proxybypasslocaladdresses' defaultValue:'True'
20-2-12 08:18:18.5|Trace|Http|Res: 343 [PUT] /api/config/host: 202.Accepted (332 ms)
20-2-12 08:18:18.5|Trace|HttpClient|Res: [GET] http://192.168.1.35:8181/api?mode=get_config&apikey=(removed)&output=json: 200.OK (18 ms)
20-2-12 08:18:18.5|Debug|Api|[PUT] /api/config/host: 202.Accepted (332 ms)
20-2-12 08:18:18.5|Trace|HttpClient|Response content (8473 bytes): {"config": {"ncenter": {"ncenter_prio_startup": 1, "ncenter_prio_warning": 0, "ncenter_cats": ["*"], "ncenter_prio_new_login": 0, "ncenter_prio_queue_done": 1, "ncenter_prio_download": 0, "ncenter_prio_failed": 1, "ncenter_prio_disk_full": 1, "ncenter_prio_error": 0, "ncenter_enable": 0, "ncenter_prio_complete": 1, "ncenter_prio_pp": 0, "ncenter_prio_other": 0}, "ntfosd": {"ntfosd_prio_queue_done": 1, "ntfosd_enable": 1, "ntfosd_cats": ["*"], "ntfosd_prio_error": 0, "ntfosd_prio_startup": 1, "ntfosd_prio_complete": 1, "ntfosd_prio_pp": 0, "ntfosd_prio_warning": 0, "ntfosd_prio_other": 0, "ntfosd_prio_disk_full": 1, "ntfosd_prio_new_login": 0, "ntfosd_prio_download": 0, "ntfosd_prio_failed": 1}, "nscript": {"nscript_cats": ["*"], "nscript_prio_complete": 1, "nscript_prio_other": 0, "nscript_prio_warning": 0, "nscript_prio_queue_done": 1, "nscript_prio_failed": 1, "nscript_prio_pp": 0, "nscript_prio_new_login": 0, "nscript_script": "", "nscript_prio_download": 0, "nscript_prio_error": 0, "nscript_prio_startup": 1, "nscript_parameters": "", "nscript_enable": 0, "nscript_prio_disk_full": 1}, "pushover": {"pushover_prio_error": 1, "pushover_cats": ["*"], "pushover_prio_failed": -1, "pushover_prio_complete": -1, "pushover_prio_warning": 1, "pushover_prio_startup": -3, "pushover_prio_queue_done": -1, "pushover_prio_other": -3, "pushover_prio_pp": -3, "pushover_enable": 0, "pushover_prio_disk_full": 1, "pushover_token": "", "pushover_device": "", "pushover_emergency_expire": 3600, "pushover_prio_new_login": -3, "pushover_emergency_retry": 60, "pushover_prio_download": -2, "pushover_userkey": ""}, "misc": {"movie_rename_limit": "100M", "https_port": "8090", "folder_rename": 1, "password_file": "", "queue_complete": "", "warned_old_queue": 10, "https_key": "server.key", "cleanup_list": [], "notified_new_skin": 2, "rating_filter_enable": 0, "cache_limit": "1G", "rating_enable": 0, "fail_hopeless_jobs": 1, "par_option": "", "web_color": "Default", "inet_exposure": 0, "enable_recursive": 1, "selftest_host": "self-test.sabnzbd.org", "pre_check": 0, "replace_spaces": 0, "host_whitelist": ["d87ea5585692"], "dirscan_speed": 5, "enable_filejoin": 1, "api_key": "(removed)", "no_penalties": 0, "load_balancing": 2, "rating_filter_abort_video": 0, "osx_speed": 1, "dirscan_dir": "", "disable_api_key": 0, "quota_period": "m", "win_menu": 1, "enable_7zip": 1, "rating_filter_pause_audio": 0, "rss_filenames": 0, "password": "", "permissions": "777", "quota_day": "", "require_modern_tls": 0, "ssl_ciphers": "", "auto_disconnect": 1, "use_pickle": 0, "https_chain": "", "warn_empty_nzb": 1, "history_limit": 10, "enable_date_sorting": 0, "enable_https_verification": 1, "replace_dots": 0, "win_process_prio": 3, "ipv6_hosting": 0, "series_propercheck": 1, "rating_host": "", "movie_sort_extra": "-cd%1", "quota_size": "", "ionice": "", "enable_unzip": 1, "download_free": "10G", "movie_categories": ["movies"], "email_dir": "", "wait_ext_drive": 5, "pre_script": "None", "ipv6_servers": 1, "enable_all_par": 0, "rating_filter_pause_encrypted_confirm": 0, "email_full": 0, "enable_tsjoin": 1, "log_dir": "logs", "rating_filter_pause_encrypted": 0, "queue_limit": 20, "admin_dir": "admin", "nzb_backup_dir": "", "tv_sort_countries": 1, "date_categories": ["tv"], "ignore_empty_files": 0, "show_sysload": 2, "sfv_check": 1, "date_sort_string": "", "schedlines": [], "host": "0.0.0.0", "ignore_unrar_dates": 0, "https_cert": "server.cert", "email_rss": 0, "sanitize_safe": 0, "req_completion_rate": 100.2, "language": "en", "movie_sort_string": "", "rating_filter_pause_spam_confirm": 0, "fixed_ports": 1, "html_login": 1, "direct_unpack_tested": 1, "api_logging": 1, "pause_on_post_processing": 0, "debug_log_decoding": 0, "allow_incomplete_nzb": 0, "rating_filter_abort_keywords": "", "enable_unrar": 1, "enable_meta": 1, "direct_unpack": 1, "url_base": "/sabnzbd", "email_account": "", "email_server": "", "converted_nzo_pickles": 1, "config_lock": 0, "quota_resume": 0, "quick_check_ext_ignore": ["nfo", "sfv", "srr"], "api_warnings": 1, "wait_for_dfolder": 0, "tv_sort_string": "", "rating_filter_abort_encrypted": 0, "rating_filter_pause_keywords": "", "warn_dupl_jobs": 1, "movie_extra_folder": 0, "web_dir": "Glitter", "no_series_dupes": 0, "rating_filter_abort_downvoted": 0, "download_dir": "/data/incomplete_downloads", "size_limit": "0", "enable_par_cleanup": 1, "safe_postproc": 1, "new_nzb_on_failure": 0, "complete_dir": "/data/complete_downloads", "x_frame_options": 1, "rating_filter_pause_downvoted": 0, "replace_illegal": 1, "rating_filter_abort_audio": 0, "nomedia_marker": "", "auto_sort": 0, "rating_filter_abort_encrypted_confirm": 0, "check_new_rel": 1, "bandwidth_max": "400M", "local_ranges": [], "enable_https": 1, "username": "", "direct_unpack_threads": 3, "no_dupes": 0, "keep_awake": 1, "top_only": 0, "osx_menu": 1, "email_from": "", "unwanted_extensions": [], "max_art_tries": 3, "rating_filter_abort_spam_confirm": 0, "email_endjob": 0, "tv_categories": [], "rss_odd_titles": ["nzbindex.nl/", "nzbindex.com/", "nzbclub.com/"], "pause_on_pwrar": 1, "rating_filter_pause_spam": 0, "backup_for_duplicates": 1, "ignore_samples": 0, "overwrite_files": 0, "multipar": 0, "rss_rate": 60, "refresh_rate": 1, "sched_converted": 2, "history_retention": "0", "propagation_delay": 0, "port": "8080", "script_can_fail": 0, "script_dir": "", "bandwidth_perc": 0, "email_pwd": "", "empty_postproc": 0, "ignore_wrong_unrar": 0, "email_cats": ["*"], "nice": "", "enable_bonjour": 1, "enable_movie_sorting": 0, "flat_unpack": 0, "fast_fail": 1, "rating_filter_pause_video": 0, "max_url_retries": 10, "fsys_type": 0, "action_on_unwanted_extensions": 0, "rating_api_key": "", "reject_duplicate_files": 0, "nzb_key": "(removed)", "max_art_opt": 0, "ampm": 0, "rating_filter_abort_spam": 0, "auto_browser": 1, "start_paused": 0, "email_to": [], "queue_complete_pers": 0, "enable_tv_sorting": 0, "folder_max_length": 256}, "growl": {"growl_prio_startup": 1, "growl_enable": 0, "growl_prio_new_login": 0, "growl_prio_other": 0, "growl_prio_download": 0, "growl_server": "", "growl_prio_disk_full": 1, "growl_prio_failed": 1, "growl_prio_queue_done": 1, "growl_prio_warning": 0, "growl_prio_error": 0, "growl_prio_complete": 1, "growl_cats": ["*"], "growl_prio_pp": 0, "growl_password": ""}, "prowl": {"prowl_prio_disk_full": 1, "prowl_prio_error": -3, "prowl_prio_download": -3, "prowl_enable": 0, "prowl_prio_failed": 1, "prowl_prio_pp": -3, "prowl_cats": ["*"], "prowl_prio_new_login": -3, "prowl_apikey": "", "prowl_prio_startup": -3, "prowl_prio_warning": -3, "prowl_prio_other": -3, "prowl_prio_complete": 0, "prowl_prio_queue_done": 0}, "acenter": {"acenter_prio_pp": 0, "acenter_prio_disk_full": 1, "acenter_prio_new_login": 0, "acenter_cats": ["*"], "acenter_prio_failed": 1, "acenter_prio_download": 0, "acenter_prio_queue_done": 1, "acenter_prio_error": 0, "acenter_enable": 0, "acenter_prio_warning": 0, "acenter_prio_complete": 1, "acenter_prio_startup": 0, "acenter_prio_other": 0}, "logging": {"max_log_size": "5242880", "log_level": 1, "log_backups": 5}, "servers": [{"username": "(removed)", "priority": 0, "enable": 1, "displayname": "news.eweka.nl", "name": "news.eweka.nl", "ssl_ciphers": "", "notes": "", "connections": 20, "ssl": 0, "host": "news.eweka.nl", "timeout": 60, "ssl_verify": 2, "send_group": 0, "password": "(removed)", "optional": 0, "port": 119, "retention": 0}], "pushbullet": {"pushbullet_prio_download": 0, "pushbullet_prio_other": 0, "pushbullet_enable": 0, "pushbullet_prio_complete": 1, "pushbullet_cats": ["*"], "pushbullet_device": "", "pushbullet_prio_failed": 1, "pushbullet_apikey": "", "pushbullet_prio_warning": 0, "pushbullet_prio_startup": 0, "pushbullet_prio_new_login": 0, "pushbullet_prio_queue_done": 0, "pushbullet_prio_disk_full": 1, "pushbullet_prio_error": 0, "pushbullet_prio_pp": 0}, "categories": [{"priority": -100, "pp": "3", "name": "tv", "script": "Default", "newzbin": "", "order": 1, "dir": "tv"}, {"priority": 1, "pp": "3", "name": "movies", "script": "Default", "newzbin": "", "order": 0, "dir": "movies"}, {"priority": 0, "pp": "3", "name": "*", "script": "None", "newzbin": "", "order": 0, "dir": ""}, {"priority": -100, "pp": "3", "name": "music", "script": "Default", "newzbin": "", "order": 2, "dir": "music"}, {"priority": -100, "pp": "3", "name": "software", "script": "Default", "newzbin": "", "order": 3, "dir": "software"}]}}
20-2-12 08:18:18.5|Trace|EventAggregator|Publishing HealthCheckCompleteEvent
20-2-12 08:18:18.5|Trace|EventAggregator|HealthCheckCompleteEvent -> HealthModule
20-2-12 08:18:18.6|Trace|EventAggregator|HealthCheckCompleteEvent <- HealthModule
20-2-12 08:18:18.6|Trace|HttpClient|Res: [GET] http://services.sonarr.tv/v1/update/master?version=2.0.0.5338&os=linux&runtimeVer=5.20.1: 200.OK (329 ms)
20-2-12 08:18:18.6|Trace|Http|Req: 344 [GET] /api/health
20-2-12 08:18:18.6|Trace|EventAggregator|Publishing HealthCheckCompleteEvent
20-2-12 08:18:18.6|Trace|Http|Res: 344 [GET] /api/health: 200.OK (8 ms)
20-2-12 08:18:18.6|Trace|EventAggregator|HealthCheckCompleteEvent -> HealthModule
20-2-12 08:18:18.6|Debug|Api|[GET] /api/health: 200.OK (8 ms)
20-2-12 08:18:19.0|Trace|Http|Req: 345 [GET] /api/health
20-2-12 08:18:19.0|Trace|Http|Res: 345 [GET] /api/health: 200.OK (11 ms)
20-2-12 08:18:19.0|Debug|Api|[GET] /api/health: 200.OK (11 ms)
20-2-12 08:18:24.6|Trace|Scheduler|Pending Tasks: 0
20-2-12 08:18:48.0|Trace|Http|Req: 347 [GET] /api/diskspace
20-2-12 08:18:48.0|Trace|Http|Req: 346 [GET] /api/health
20-2-12 08:18:48.0|Trace|Http|Res: 346 [GET] /api/health: 200.OK (8 ms)
20-2-12 08:18:48.0|Debug|Api|[GET] /api/health: 200.OK (8 ms)
20-2-12 08:18:48.1|Trace|Http|Req: 348 [GET] /api/health
20-2-12 08:18:48.1|Trace|Http|Res: 348 [GET] /api/health: 200.OK (4 ms)
20-2-12 08:18:48.1|Debug|Api|[GET] /api/health: 200.OK (4 ms)
20-2-12 08:18:48.2|Trace|ConfigService|Using default config value for 'downloadedepisodesfolder' defaultValue:''
20-2-12 08:18:48.3|Trace|Http|Res: 347 [GET] /api/diskspace: 200.OK (281 ms)
20-2-12 08:18:48.3|Debug|Api|[GET] /api/diskspace: 200.OK (281 ms)
20-2-12 08:18:48.4|Trace|Http|Req: 349 [GET] /api/diskspace
20-2-12 08:18:48.6|Trace|ConfigService|Using default config value for 'downloadedepisodesfolder' defaultValue:''
20-2-12 08:18:48.6|Trace|Http|Res: 349 [GET] /api/diskspace: 200.OK (262 ms)
20-2-12 08:18:48.6|Debug|Api|[GET] /api/diskspace: 200.OK (262 ms)
20-2-12 08:18:49.4|Trace|Http|Req: 350 [GET] /api/log?page=1&pageSize=50&sortKey=time&sortDir=desc&filterKey=level&filterValue=Error
20-2-12 08:18:49.5|Trace|Http|Res: 350 [GET] /api/log?page=1&pageSize=50&sortKey=time&sortDir=desc&filterKey=level&filterValue=Error: 200.OK (53 ms)
20-2-12 08:18:49.5|Debug|Api|[GET] /api/log?page=1&pageSize=50&sortKey=time&sortDir=desc&filterKey=level&filterValue=Error: 200.OK (53 ms)
20-2-12 08:18:49.6|Trace|Http|Req: 351 [GET] /api/log?page=1&pageSize=50&sortKey=time&sortDir=desc&filterKey=level&filterValue=Error
20-2-12 08:18:49.7|Trace|Http|Res: 351 [GET] /api/log?page=1&pageSize=50&sortKey=time&sortDir=desc&filterKey=level&filterValue=Error: 200.OK (19 ms)
20-2-12 08:18:49.7|Debug|Api|[GET] /api/log?page=1&pageSize=50&sortKey=time&sortDir=desc&filterKey=level&filterValue=Error: 200.OK (19 ms)
20-2-12 08:18:50.9|Trace|Http|Req: 352 [GET] /api/log/file
20-2-12 08:18:50.9|Trace|Http|Res: 352 [GET] /api/log/file: 200.OK (14 ms)
20-2-12 08:18:50.9|Debug|Api|[GET] /api/log/file: 200.OK (14 ms)
20-2-12 08:18:51.1|Trace|Http|Req: 353 [GET] /api/log/file/sonarr.trace.txt
20-2-12 08:18:51.1|Trace|Http|Res: 353 [GET] /api/log/file/sonarr.trace.txt: 200.OK (6 ms)
20-2-12 08:18:51.1|Debug|Api|[GET] /api/log/file/sonarr.trace.txt: 200.OK (6 ms)
20-2-12 08:18:53.1|Trace|Http|Req: 354 [GET] /api/log/file/sonarr.trace.txt
