Sonarr version (3.0.1.408):
OS: Windows 10
((https://drive.google.com/file/d/1pCM6OT0IZlv-vEMHi3iJZrkvCuXPB67l/view?usp=sharing)):
This is the first time I’ve tried sharing with Google Drive so please bear with me if something is wrong.
Under Settings/Connect, added the Plex authorization token to restore my previously defined connection to Plex. Did NOT select On Grab, On Import, or On Rename but did check the box to update library.
Connection box shows as disabled without one of the three boxes noted above checked.
The log file seems to say that the authorization token that Sonarr got from Plex isn’t valid…
