Please allow us to manually set download directories instead of using categories
Hi.
Just switched over from Sickrage. The one thing that bothers me about Sonarr is that it forces me to change how I use transmission. On Couchpotato, I can set a download directory that it will pass to transmission and will be able to post process from that location.
With Sonarr, I am forced to tell Transmission to default all my downloads to my TV show directory just so that Sonarr can set up the category subfolder in the right place…but this really messes with my general watch folder for random torrents that I snatch.
Are there any plans to allow us this? This is one of the major things I noticed was different from Sickrage and I really miss that ability.
Sorted and unsorted files in the same place? We definitely recommend against that, as long as Sonarr can hardlink them to the series folder (same disk or volume) they should definitely be kept separate.
Its being considered, https://github.com/Sonarr/Sonarr/issues/744
No, I don’t mean that the downloads go to where the sorted TV shows are. I am talking a folder like Sickrage and Couchpotato has where your torrent client will dumb the unprocessed files. Sonarr should be able to read from there and post-process as usual.
Thank you for the github link, Im looking over it now.
