This looks to be an authentication error when pulling from the API, but I’m not sure if it’s a problem with Sonarr or NZB360. There is a post on the NZB360 forums, but I thought I should post here to see if you know where the problem might be.
I’m running Develop version: 2.0.0.2794
Here’s the NZB360 forum post: NZB post
Here’s what my Sonarr logs are showing:
NzbDroneErrorPipeline Request Failed: Object reference not set to an instance of an object
Exception
System.NullReferenceException: Object reference not set to an instance of an object
at NzbDrone.Core.Authentication.UserService.FindUser (System.String username, System.String password) [0x00000] in <filename unknown>:0
at NzbDrone.Api.Authentication.AuthenticationService.Validate (System.String username, System.String password) [0x00000] in <filename unknown>:0
at Nancy.Authentication.Basic.BasicAuthentication.RetrieveCredentials (Nancy.NancyContext context, Nancy.Authentication.Basic.BasicAuthenticationConfiguration configuration) [0x00000] in <filename unknown>:0
at Nancy.Authentication.Basic.BasicAuthentication+<>c__DisplayClass1.<GetCredentialRetrievalHook>b__0 (Nancy.NancyContext context) [0x00000] in <filename unknown>:0
at Nancy.BeforePipeline+<>c__DisplayClass4.<Wrap>b__3 (Nancy.NancyContext ctx, CancellationToken ct) [0x00000] in <filename unknown>:0
Message
Exception
Message
Exception
Message
Exception
